Anyway enough of my waffling back to the review.
CD player plays CDs! No surprises there I'm sure, but it also carries out many extra operations that soon keep you away from your Hi Fi's player as it is not so useful.
It can carry out all the usual functions associated with a typical CD
Player: skip track, shuffle, scan, pause and program. It has a time
display that can be toggled through total time of disc or track and
time remaining of disc or track. Nothing unusual so far, in fact a
pretty standard player. Let's get to the extras as everybody knows
what your average CD player can do.
Included in the play-mode functions you'll find a play block operation. This is great for playing sections of your favourite tracks over and over again. Using the mark block keys you select the section of the track you wish to listen to, or dare I say, record [tut, tut, tut - FFF]. When the player starts to play the section in question left click on the 'A' button, at the end of the section you're marking as a block left click on the 'B' button. CD-Player will then keep the block details in memory for you to manipulate as you see fit. The block, once selected can be played back as we've already mentioned or, more usefully, using a built in export track function recorded to your hard drive (Your CD-ROM has to support this function, most up to date CD-ROM drives do).
The average everyday user will find CD-Player's database facility and its cassette calculator far more useful.
Put a CD in the drive and CD-Player allows you to enter Artist and track titles. The next time this CD is used it will display the CD and track titles in its window. There is also a popup which allows you to pick tracks by name.
CD-Player can be run as an accessory under normal TOS and works well as a program under Geneva and MagiC 4. I haven't tested it under Multi-TOS but I'd assume it would work well there too. It can be used in conjunction with MetaDOS or ExtenDOS without problems. In fact in many months of use it hasn't crashed once. CD-Player is a truly excellent piece of software, you won't go far wrong with this.
